[Qgis-developer] [info] openstreetmap shapefile data
kimaidou michael.douchin at laposte.net
Thu Jul 3 07:30:08 EDT 2008
Totally agree with you
This is completely different way of accessing the data from osm.
You say that the osm format is well documented. Why not creating a special
wiki page on this topic ?
We can start without any line of code : what needs, what functions, etc.
Here 's a start from scratch : functionnality needed and quick writtent
related questions :
Download :
* connect to openstreetmap server
Questions/Remarks: does it exist one, several, can anyone connect to it ?
* let the user select a geographical zone from which dowload data:
Q/R : - we need a basic world map (which projection ? WGS84 ?)
- the user must be able to enter directly the box coordinates if he knows
them
- provide some quick access list (2 levels : continent --> countries)
* let the user select the features he wants to download (only primary road,
only footpahs..)
Q/R: - choose wich list of osm tags to propose (see osm wiki page)
- we can look at the work done in my previous link to get an idea of how to
organize data.
* transform the osm data into ogr format ?
Q/R : - in which format : gml (well documented, xml), shapefile, kml ?)
- Don't know how the geometries are managed under osm : simple and complex
ones (polygon with holes, multigeom, etc.) --> Is there a total
compatibility, or do we need to convert some geometries in others ?
- the converted data must be saved in the temp file of the os
Edition :
* here we must look at josm interface and see what functionnality to keep.
Ok I will stop here and wait for any remark /reply
Michael
Paolo Cavallini wrote:
> The idea behind the plugin is to use OSM data directly, including the
> editing and the upload of new traces, thus effectively replacing the
> "official" josm (java, brrr) editing tool.
> It shouldn't be *too* difficult: the OSM XML is well documented, it
> should "only" be parsed back and forth.
> pc
> Paolo Cavallini, see: * http://www.faunalia.it/pc *
View this message in context: http://www.nabble.com/-info--openstreetmap-shapefile-data-tp18256685p18257233.html
Sent from the qgis-developer mailing list archive at Nabble.com.
