[Qgis-developer] Interpolation plugin
Tim Sutton
tim at linfiniti.com
Tue Jul 8 04:10:47 EDT 2008
Hi Marco
Cool stuff! I tried to compile but the CMakeLists.txt seems to be
missing from your tarball.
Regards
Tim
2008/7/8 Marco Hugentobler <marco.hugentobler at karto.baug.ethz.ch>:
> Hi all,
> I wrote a plugin for spatial interpolation. The plugin is still in
> experimental stage. However, it already is possible to produce raster layer
> (ascii grid format by now) from a vector layer using linear triangulation or
> inverse distance weighting. The plugin code is here:
> http://karlinapp.ethz.ch/interpolation_plugin.tgz
> To compile, unpack in src/plugins directory and add 'interpolation' to the
> first line in src/plugins/CMakeList.txt:
> SUBDIRS (copyright_label delimited_text grid_maker north_arrow scale_bar
> interpolation)
> The code for triangular interpolation originates from my phd several years
> ago. There are some capabilities that are provided by this code which are not
> accessible through the plugin GUI yet:
> - cubic triangular interpolation (clough-tocher methode or coons patch)
> - modify the delaunay triangulation by swapping edges
> - mark input data as constrained triangle edges or breaklines
> The interpolation plugin is generic enough to support other type of
> interpolation methods. If you want to see your favorite interpolation method
> in QGIS, all you have to do is to provide a subclass of QgsInterpolator and a
> subclass of QgsInterpolatorDialog that takes the parameter for the
> interpolation method.
> Regards,
> Marco
> Dr. Marco Hugentobler
> Institute of Cartography
> ETH Zurich
> Technical Advisor QGIS Project Steering Committee
> Qgis-developer mailing list
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
