[Qgis-developer] Re: Labels in OS X
John C. Tull john.tull at wildnevada.org
Thu Jul 10 12:38:55 EDT 2008
Thanks for the test. I just cannot think what is causing my problems
with labels on the canvas... Care to share your Qt configure
arguments? Maybe there's a problem there, although I tried the binary
installer as well as home-rolled with the same label problem in either
situation.
Cheers,
John
On Jul 9, 2008, at 11:30 PM, Tom Elwertowski wrote:
> John,
> Labels work for me using current svn, Qt 4.4.0 and OS X 10.5.4. I
> don't use Python. Trying to match your example, all I did was select
> a label field in the Vector Layer Properties dialog and check Buffer
> Labels.
> Tom
> John C. Tull wrote:
>> Tom,
>> I was wondering if you have been seeing problems with labels in
>> qgis using qt-4.4.0, pyqt-4.4.2? Below is an example of how my
>> labels are being truncated to rightmost characters in the map
>> canvas. It seems to be something like a 50% truncation, so long
>> labels show more characters than short labels, but everything is
>> being cut short.
>> Someone on irc and linux with qt-4.4.0 did not have this problem,
>> so I am trying to see if this is happening with other Mac users.
>> I have built the most current svn, am on 10.5.4, and seemed to only
>> have this problem after upgrading Qt.
>> Regards,
>> John
