[Qgis-developer] should QGIS modify files access permissions?
Jürgen E. Fischer
jef at norbit.de
Fri Jul 11 08:00:04 EDT 2008
Hi Maciej,
On Fri, 11. Jul 2008 at 10:27:24 +0200, Maciej Sieczka wrote:
> What do you think about this issue? Am I correct to expect that QGIS
> should not change access rights of files it edits?
I don't think it does. Actually I don't think it cares at all as it
only calls libraries, so I'd expect the same when you work with GRASS
directly.
Those are probably also not changing any access rights explictly, but
are just creating, deleting and removing files when editing.
In that case setting umask to 0007 might help, if you don't want
world-readable files (at least on *x).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-0
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
