[Qgis-developer] should QGIS modify files access permissions?
Maciej Sieczka
tutey at o2.pl
Fri Jul 11 09:26:37 EDT 2008
Jürgen E. Fischer pisze:
> On Fri, 11. Jul 2008 at 10:27:24 +0200, Maciej Sieczka wrote:
>> What do you think about this issue? Am I correct to expect that
>> QGIS should not change access rights of files it edits?
> I don't think it does. Actually I don't think it cares at all as it
> only calls libraries, so I'd expect the same when you work with
> GRASS directly.
Right, I should have checked that - indeed the problem is down to GRASS,
not QGIS.
> Those are probably also not changing any access rights explictly, but
> are just creating, deleting and removing files when editing.
So it seems. umask helps.
Cheers,
Maciek
Maciej Sieczka
www.sieczka.org
