[Qgis-developer] Re: Labels in OS X
Tom Elwertowski
telwertowski at comcast.net
Sat Jul 12 16:15:02 EDT 2008
If you haven't already checked, open the Attribute Table display and check the label column. If the column is ok, do the following.
In core/qgslabel.cpp, add the line
qDebug() << "Label:" << text;
after the block:
/* Text */
value = fieldValue ( Text, feature );
if ( value.isEmpty() )
text = mLabelAttributes->text();
else
text = value;
Also add the line "#include <QDebug>" to the top of the file.
The new debug line should be line 116.
Build and run qgis from a terminal and you will see the label text extracted from the features. It should be the same as displayed in the attribute table. If the text is complete, the problem is in the next ~300 lines and more qDebug lines can be added to find it.
Tom
John C. Tull wrote:
> I rebuilt, this time with demos and examples. I cannot find anything out
> of the ordinary perusing the examples and demos, but I'm not sure if
> there is anything quite like the labels used for vector items in qgis.
> If you know of a specific example, I'll do some more testing. Otherwise,
> I'm stymied.
> Regarding the string check, I'm not sure how to test that.
> Thanks,
> John
