[Qgis-developer] Re: Labels in OS X
John C. Tull
john.tull at wildnevada.org
Sat Jul 12 19:06:22 EDT 2008
On Jul 12, 2008, at 1:15 PM, Tom Elwertowski wrote:
> If you haven't already checked, open the Attribute Table display and
> check the label column. If the column is ok, do the following.
Labels are fine. This happens with all vector layer labeling, no
matter the source.
> In core/qgslabel.cpp, add the line
> qDebug() << "Label:" << text;
Changed to QDebug ...
> after the block:
> /* Text */
> value = fieldValue ( Text, feature );
> if ( value.isEmpty() )
> text = mLabelAttributes->text();
> else
> text = value;
> Also add the line "#include <QDebug>" to the top of the file.
Done
> The new debug line should be line 116.
Done.
> Build and run qgis from a terminal and you will see the label text
> extracted from the features. It should be the same as displayed in
> the attribute table. If the text is complete, the problem is in the
> next ~300 lines and more qDebug lines can be added to find it.
Build is unsuccessful:
[ 14%] Building CXX object src/core/CMakeFiles/qgis_core.dir/
qgssearchstring.o
/Users/jctull/sources/qgis/trunk/src/core/qgslabel.cpp: In member
function void QgsLabel::renderLabel(QPainter*, const QgsRect&, const
QgsCoordinateTransform*, const QgsMapToPixel*, QgsFeature&, bool,
QgsLabelAttributes*, double):
/Users/jctull/sources/qgis/trunk/src/core/qgslabel.cpp:118: error: no
matching function for call to QDebug::QDebug()
/usr/local/Trolltech/Qt-4.4.0/include/QtCore/qdebug.h:80: note:
candidates are: QDebug::QDebug(const QDebug&)
/usr/local/Trolltech/Qt-4.4.0/include/QtCore/qdebug.h:79:
note: QDebug::QDebug(QtMsgType)
/usr/local/Trolltech/Qt-4.4.0/include/QtCore/qdebug.h:78:
note: QDebug::QDebug(QString*)
/usr/local/Trolltech/Qt-4.4.0/include/QtCore/qdebug.h:77:
note: QDebug::QDebug(QIODevice*)
make[2]: *** [src/core/CMakeFiles/qgis_core.dir/qgslabel.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
make: *** [all] Error 2
John
