[Qgis-developer] QGIS 0.11.0 'Metis' - Call for packaging
Jürgen E. Fischer jef at norbit.de
Mon Jul 14 04:54:27 EDT 2008
Hi Otto,
On Mon, 14. Jul 2008 at 10:43:20 +0200, Otto Dassau wrote:
> [ 9%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgsapplication.o
> /usr/src/packages/BUILD/qgis-0.11.0/src/core/qgsapplication.cpp: In static
> member function 'static QString QgsApplication::reportStyleSheet()':
> /usr/src/packages/BUILD/qgis-0.11.0/src/core/qgsapplication.cpp:272: error:
> 'class QColor' has no member named 'lighter' make[2]: ***
> [src/core/CMakeFiles/qgis_core.dir/qgsapplication.o] Error 1 make[1]: ***
> [src/core/CMakeFiles/qgis_core.dir/all] Error 2 make: *** [all] Error 2
> error: Bad exit status from /var/tmp/rpm-tmp.4612 (%build)
> opensuse 10.2 uses libqt4-4.2.1-18 and fails opensuse 10.3 uses libqt4-4.3.1-23
> and works. Do I definitely need qt4 >= version 4.3 or is this another problem?
Yes.  There was a vote about dropping 4.2 support.  See
http://lists.osgeo.org/pipermail/qgis-developer/2008-May/003759.html
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
