[Qgis-developer] QGIS 0.11.0 'Metis' - Call for packaging
Otto Dassau otto.dassau at gmx.de
Mon Jul 14 09:35:24 EDT 2008
there are now QGIS 0.11.0 test packages available for OpenSuSE 10.3 and 11.0 via
the Application:/Geo repository. I won't package for OpenSuSE 10.2, except there
are many 10.2 users who complain and can't update their system :-).
http://download.opensuse.org/repositories/Application:/Geo/
regards,
 Otto
On Mon, 14 Jul 2008 10:43:20 +0200
Otto Dassau <otto.dassau at gmx.de> wrote:
> Hi,
> There is a problem compiling QGIS on OpenSUSE Version <= 10.2.
> [ 9%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgsapplication.o
> /usr/src/packages/BUILD/qgis-0.11.0/src/core/qgsapplication.cpp: In static
> member function 'static QString QgsApplication::reportStyleSheet()':
> /usr/src/packages/BUILD/qgis-0.11.0/src/core/qgsapplication.cpp:272: error:
> 'class QColor' has no member named 'lighter' make[2]: ***
> [src/core/CMakeFiles/qgis_core.dir/qgsapplication.o] Error 1 make[1]: ***
> [src/core/CMakeFiles/qgis_core.dir/all] Error 2 make: *** [all] Error 2
> error: Bad exit status from /var/tmp/rpm-tmp.4612 (%build)
> opensuse 10.2 uses libqt4-4.2.1-18 and fails opensuse 10.3 uses
libqt4-4.3.1-23
> and works. Do I definitely need qt4 >= version 4.3 or is this another problem?
>  regards,
>   Otto
> On Mon, 14 Jul 2008 02:20:41 +0200
> "Tim Sutton" <tim at linfiniti.com> wrote:
> > Hi Folks (and especially package makers and release team)
> > Tonight I created the release branch (revision 8769) for 0.11.0 Metis:
> > svn co https://svn.osgeo.org/qgis/branches/Release-0_11_0
> > Only packaging related changes should be made against this branch. If
> > the kind folks who usually create packages for various platforms and
> > distros could set about making 0.11.0 packages we would be most
> > grateful. The list of normal packagers is listed at the top of:
> > http://wiki.qgis.org/qgiswiki/ReleaseChecklist0.11.0
> > If you are not able to package this release and are listed on the page
> > above please let me know, If you are able to package for a new
> > platform / distro please let me know and I will add your name to the
> > list.
> > Release team please note that I moved the date of final announcement
> > of release to 21 July 2008. It will be great to have all press
> > announcements ready for then!
> > Many thanks once again to all those helping to prepare this release!
> > Best regards
> Qgis-developer mailing list
