[Qgis-developer] Error installing QGIS 0.11.0 on Windows using
	MinGW
    Marco Pasetti
    marcopstt at gmail.com
    Tue Jul 15 12:26:13 EDT 2008
Hi Tim,
> Only the obvious ones:
> - does the source file exist?
yes, it does
> - does the dest dir exist?
I guess the problem is the dot in
"c:/msys/local/qgis-0.11.0/./themes/default/grass/grass_delete_map.png"
> - do you have adequate perms to put things in the dest dir?
yes, obviously
I think that something went wrong with the configure, placing a dot in the
QGIS_DATA_DIR variable;
see also this screenshot that shows what happens when I launch qgis:
http://www.webalice.it/marco.pasetti/temp/QgisError.png
Regards,
Marco
