[Qgis-developer] Error installing QGIS 0.11.0 on Windows using MinGW
Jürgen E. Fischer jef at norbit.de
Tue Jul 15 13:27:25 EDT 2008
Hi Marco,
On Tue, 15. Jul 2008 at 18:26:13 +0200, Marco Pasetti wrote:
> >- does the dest dir exist?
> I guess the problem is the dot in
> "c:/msys/local/qgis-0.11.0/./themes/default/grass/grass_delete_map.png"
> see also this screenshot that shows what happens when I launch qgis:
> http://www.webalice.it/marco.pasetti/temp/QgisError.png
I doubt it.  The dot should be fine.  And why should it suddenly become
a problem for grass_delete_map.png, when it worked for all the other
PNGs above - even some to the same directory.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
