[Qgis-developer] New QGIS 0.11.0 Metis Windows Pre-Release Test
Installer
Marco Pasetti
marcopstt at gmail.com
Fri Jul 18 05:40:11 EDT 2008
Hi all,
I hope that this will be the last one (and it should be).
Thanks to Jurgen again fo fixing the python search path bug.
http://gigamaildownload.rossoalice.alice.it/download/download.aspx?AttachmentID=0c4d7e2e-798b-4a67-940f-2af1d6082f12&MessageID=9578efcd-5afe-4554-9349-49091ba8ebb9
Cheers,
Marco
----- Original Message -----
To: "QGIS Developer Mailing List" <qgis-developer at lists.osgeo.org>
Sent: Thursday, July 17, 2008 4:05 PM
Subject: [Qgis-developer] New QGIS 0.11.0 Metis Windows Pre-Release
TestInstaller
> Hi all,
> thanks to Jurgen I finally solved the mistery of the missing python
> plugins.
> I built a new pre-release test installer of Metis. Please test it,
> specially the GPS importer that I cannot test by myself.
> http://gigamaildownload.rossoalice.alice.it/download/download.aspx?AttachmentID=e8dbc97e-a0ae-48fe-9e2e-1696ec26cb4a&MessageID=5ac04c42-91e5-4d85-a1d7-225ab1e2ebd9
> Let me tell about the changes introduced in this new binary release:
> # Switched from the Windows XP based build environment to Windows Vista
> # Added MSYS coreutils package (required by some GRASS modules and
> scripts)
> # Added the Libjpeg (6b) library
> # Added the JPEG support in Libtiff
> # Added the JPEG support in GRASS
> # Added the JPEG support in QGIS
> # Libpng upgraded from (1.2.24) to (1.2.29)
> # GSL upgraded from (1.9) to (1.11)
> # GEOS upgraded from (2.2.3) to (3.0.0)
> # PostgreSQL upgraded from (8.2.6) to (8.3.1)
> # SQLite updated from (3.5.6) to (3.5.9)
> # GDAL upgraded from (1.5.1) to (1.5.2) *
> * with GEOS, Expat, PostgreSQL and SQLite support enabled
> # Added AVCE00 (2.0.0) [avcexport.exe and avcimport.exe]
> # Added E00compr (1.0.0) [e00conv.exe]
> # Added GPSBabel (1.3.5) [gpsbabel.exe]
> # Qt OpenSource libraries upgraded to (4.4.0)
> # Python library upgraded to (2.5.2)
> # SIP upgraded to (4.7.6)
> # PyQt upgraded to (4.4.2)
> # Redisegned the sample data download section of the installer
> # Improved the installer adding the feature of automatically recognize if
> and what release of GRASS is already installed on the system
> # Improved the installer structure with the ability of automatically
> perform upgrade, downgrade or repair installations
> Hope you like it ;)
> Regards,
> Marco
> Qgis-developer mailing list
