[Qgis-developer] error in vector split plugin
cfarmer cfarmer at uvic.ca
Fri Jul 25 13:13:53 EDT 2008
Paolo,
> I have a very long filename:
> fix_uso_modello_random_tutti_anni_grass.shp
> could it be a reason?
> In  /home/paolo/Desktop/Lia_GRASS/ as well as in
> /home/paolo/Desktop/Christopher/ it does not work, in
> /home/paolo/Desktop/ it does.
Yes, I think it is quite likely that this is the reason. Judging from your
description above (works for shorter paths, not longer ones), it sounds
like the output names are getting too long. The plugin takes the layer
name plus the attribute name to create a new layer name: this would
produce an extremely long file name, which may be too long for the
shapefile writer. Maybe try exporting the layer to a new shapefile, giving
it a shorter name, and try again? Let me know what happens.
> I press on Browse, then up a folder, but Choose is unactivated. I have
> to select the folder to be able to choose the folder.
> If I remember correctly, I could select the folder I was into, without
> the need to go up one level and click on the folder name (two extra
> clicks required, potentially confusing). But it's obviously a very minor
> thing.
I thought this was always the case? I'm not sure why this would have
changed? It way be that we are stuck with this behaviour, but I'll see if
you can get it back to the way you describe it...
> If I select a subfoder respect to the one I was trying (unsuccessfully)
> to split mt vector before, qgis freezes...
Hmmm, this behavior is odd, and not good. I'll try to produce the same
errors here.
Cheers,
Carson
