[Qgis-developer] WMS-Proxy settings broken?
Stephan Holl stephan.holl at intevation.de
Wed Jun 11 08:50:50 EDT 2008
Hello Tim,
"Tim Sutton" <tim at linfiniti.com>, [20080611 - 14:24:37]
> Hi guys
> Marco ok thanks for the  clarificatio - I'll try to implement proxy
> settings centralisation over the next few days so leave it to me. i
> dont think its the qt3 port that is the cause of the issue if the
> problem is present in 0.10.0 too. Stephan QGIS 0.11.0 will be out at
> the end of the month so I dont expect to backport any fixes to 0.10.0.
No problem. I just wanted to make sure that proxy-settings will be
repaired in the next release, and if it will be centralized, even
better! This makes the project-files more transportable though.
Thanks Tim for the offer to implement it befor 0.11.0. I am happy to
give you feedback when you have included it.
Since I heavily use QGIS
through a security-proxy[1] to access secured WMS/WFS I need the
proxy-settings in QGIS, because it does not reflect the environment
variables http_proxy/https_proxy.
Best
	Stephan
[1] http://inteproxy.wald.intevation.org
> On 6/11/08, Stephan Holl <stephan.holl at intevation.de> wrote:
> > Hallo Marco, Tim,
> > "Hugentobler  Marco" <marco.hugentobler at karto.baug.ethz.ch>,
> > [20080611
> > - 10:49:17]
> >> Hi,
> >> I only changed the plugin interface, not the WMS dialog/provider
> >> itself. Afaik, there have been some ui changes in the WMS dialog to
> >> remove qt3 compatibility classes.
> >> Centralizing the proxy stuff in options, as suggested by Tim, is a
> >> good idea. I haven't started with this and I'm quite busy at the
> >> moment, so if someone feels like implementing this, it would be
> >> very welcome.
> > Yes, this is definitely a good idea, but some of my clients do
> > need the proxy-settings for WMS, it would be good to provide a fix
> > (since it is broken in 0.10.0 as well) for the current version
> > though.
> > Best regards
> > 	Stephan
> > Stephan Holl <stephan.holl at intevation.de>,
> > http://intevation.de/~stephan Tel: +49 (0)541-33 50 8 32 |
> > Intevation GmbH | AG Osnabrück - HR B 18998 Geschäftsführer:  Frank
> > Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
