[Qgis-developer] no Polish chars in table, labels, query results!
Marco Hugentobler marco.hugentobler at karto.baug.ethz.ch
Tue Jun 24 05:01:10 EDT 2008
Hi Maciej,
I tried it with german Umlaute (öüä) and they display ok in the attribute
table and the query results. If you load from shape, are you sure you
selected the right encoding in the combo box of the file dialog?
If you think it is a QGIS related problem, then it is probably best to check
out a revision from a couple of weeks ago as you suggest:
svn co --revision {yyyy-mm-dd}
Regards,
Marco
Am Dienstag 24 Juni 2008 10:31:44 schrieb Maciej Sieczka:
> Maciej Sieczka pisze:
> > Dear Devs,
> > Whatever happened that QGIS no longer displays Polish (pl UTF-8
> > locale) characters anymore in the table, labels and query results? It
> > also fails to save a newly created sahpefile if it's name contains
> > Polish chars like ąęćń etc.
> > I can bet this all used to work couple of weeks ago! Please can you
> > fix it back before tomorrow? I'm going to give a "farewell"
> > presentation at my institute using QGIS among the others...
> At least, what is the latest revision not affected? I still have 2,5 hour
> left.
> Maciek
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
