[Qgis-developer] Problem with python bindings
Carlos Dávila
cdavilam at jemila.jazztel.es
Mon Mar 3 12:13:31 EST 2008
Martin Dobias escribió:
> On Fri, Feb 29, 2008 at 5:14 PM, Carlos Dávila
> <cdavilam at jemila.jazztel.es> wrote:
>> First of all, sorry for the delay in my answer, but until this morning I
>> had no opportunity to test. As you suggested, I needed python-qt4-dev
>> package. Now configure is right, but I get an error on make: unable to
>> find /qgis/python/core/core.sbf. I think this file should be generated
>> by make, but for any reason it is not. New suggestions?
> Make also sure that you have installed sip4 package.
I have installed sip4, python-sip4 and python-sip4-dev packages, but it
doesn't work. I have the same packages in another machine where it works
fine.
> I would suggest you to try to make a clean build...
I had already done it, but with no results.
Regards
Carlos
