[Qgis-developer] Problem with python bindings
Martin Dobias
wonder.sk at gmail.com
Tue Mar 4 07:07:28 EST 2008
On Mon, Mar 3, 2008 at 6:13 PM, Carlos Dávila
<cdavilam at jemila.jazztel.es> wrote:
> Martin Dobias escribió:
> > On Fri, Feb 29, 2008 at 5:14 PM, Carlos Dávila
> >> First of all, sorry for the delay in my answer, but until this morning I
> >> had no opportunity to test. As you suggested, I needed python-qt4-dev
> >> package. Now configure is right, but I get an error on make: unable to
> >> find /qgis/python/core/core.sbf. I think this file should be generated
> >> by make, but for any reason it is not. New suggestions?
> > Make also sure that you have installed sip4 package.
> I have installed sip4, python-sip4 and python-sip4-dev packages, but it
> doesn't work. I have the same packages in another machine where it works
> fine.
> > I would suggest you to try to make a clean build...
> I had already done it, but with no results.
Can you tak a look to the python/core and python/gui directories in
the svn checkout? Do you see only .sip files or are there also
core.sbf resp. gui.sbf files?
Martin
