[Qgis-developer] Problem with python bindings
Carlos Dávila cdavilam at jemila.jazztel.es
Tue Mar 4 11:49:09 EST 2008
Martin Dobias escribió:
> On Mon, Mar 3, 2008 at 6:13 PM, Carlos Dávila
>>> On Fri, Feb 29, 2008 at 5:14 PM, Carlos Dávila
>>  >>  First of all, sorry for the delay in my answer, but until this morning I
>>  >>  had no opportunity to test. As you suggested, I needed python-qt4-dev
>>  >>  package. Now configure is right, but I get an error on make: unable to
>>  >>  find /qgis/python/core/core.sbf. I think this file should be generated
>>  >>  by make, but for any reason it is not. New suggestions?
>>  > Make also sure that you have installed sip4 package.
>>  I have installed sip4, python-sip4 and python-sip4-dev packages, but it
>>  doesn't work. I have the same packages in another machine where it works
>>  fine.
>>> I would suggest you to try to make a clean build...
>>  I had already done it, but with no results.
> Can you tak a look to the python/core and python/gui directories in
> the svn checkout? Do you see only .sip files or are there also
> core.sbf resp. gui.sbf files?
Only .sip files in both directories.
