[Qgis-developer] Re: [Qgis-user] vector editing in QGIS -
questions and issues (PostGIS biased)
Carlos Dávila
cdavilam at jemila.jazztel.es
Tue Mar 4 12:24:15 EST 2008
Marco Hugentobler escribió:
> Hi,
> I changed the behaviour now such that the snapping settings is only changed if
> the user really opened the project snapping dialog and clicked 'ok'.
> I'm quite open to suggestions about what reasonable defaults should be (this
> was the main point of our discussion below). Possibilities are:
> - snap to editing layer with default tolerance but not to background layers.
> This is the current default and the suggestion of Micha.
> And it's the same as the behaviour prior to the merge of the advanced editing
> branch (it was not possible then to snap to background layers)
> - snap to all vector layers using default snapping tolerance. This was what
> Maciej suggested below.
I think there could be three excluding options:
* No snapping (default)
* Snap all layers in the same way, with the following tolerance: X
* Snap to individual layers: opens snapping options dialog
Regards
Carlos
>> I'd be also in favor
>> of enabling the QGIS "topological editing" feature by default.
> +1
> cheers,
> Marco
> Am Dienstag 04 März 2008 12:08:26 schrieb Micha Silver:
>> Maciej Sieczka wrote:
>>> Marco Hugentobler pisze:
>>>> Maciek wrote:
>>>>> Marco wrote:
>>> Before you read on: NOTICE - I'm assuming that snapping = 0 is no
>>> different than snapping "disabled". Is this correct? If it is, maybe
>>> it would be better to remove the snapping checkbox for layers and use
>>> spinbox with numbers only to simplify the dialog?
>>>> Ok, I see what you mean. In the snapping dialog of the project should
>>>> be inserted the default snapping settings (which is snapping to the
>>>> active layer with the default snapping tolerance) in case the
>>>> snapping dialog was not changed already.
>>> Yes.
>>>> Otherwise, if a user changes any project property and clicks ok, the
>>>> snapping will be off for all layers.
>>> I think differently. As long as default QGIS-wide snapping is !=0, all
>>> layers which don't have inddividual setting set by the user, should
>>> have snapping set on equal to default setting - unless the user
>>> manually disables snapping for the given layer.
>>>> I don't think that unchecked layers should automatically have the
>>> Then what is the point of default snapping setting at all? Look - as
>>> long as you don't enter project properties and click OK, the default
>>> QGIS snapping is on for all layers in the project. Once you go to
>>> project props. and click OK, all snapping is suddenly disabled,
>>> although you did not modify any setting related to snapping. Imagine a
>>> user trying to guess what happened.
>> In the kind of jobs I do, and what I can imagine others do, I would NOT
>> want snapping automatically to all layers, but only the one layer I have
>> set to snap. Maybe, as you suggest, there should not be any default
>> project snapping setting at all, now that we have snapping for
>> individual layers.
>>> Note also that this was different in QGIS before introducing
>>> individual snapping setting per layer. You only had the QGIS-wide
>>> snapping setting, which was always active, for all layers. Now as soon
>>> as you go to project settings for whatever reason and press OK that
>>> snapping is disabled. This should be avoided.
>>>> Because it is possible that a user don't want to snap to some layers
>>>> at all.
>>> The user can disable snapping for a certain layer, if he needs to.
>>> Another thing - IMO users more often need snapping than they don't.
>>> Help users not to digitize overlapping features by default, eg.
>>> promote using snapping rather than not using it. I'd be also in favor
>>> What I hate most in GIS are all those overlapping polygons and lines
>>> which I have to tediously correct topology for, re-calculate their
>>> area and length, explain the vendor what is wrong about his data.
>>> Please promote topological practices.
>>> Maciek
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> This mail was sent via Kinneret Mail-SeCure System.
