AW: [Qgis-developer] Trolltech is Not Porting Qt3Support for
64-bit MacBuilds
Tim Sutton
tim at linfiniti.com
Fri Mar 7 19:05:44 EST 2008
Hi
I vaguely remember someone building on Solaris in the past but it was
long ago and I dont remember who it was. When compiling Qt4 you need
basically
QtCore
QtGui
Qt3Support (for now)
QtXml
QtSvg
QtSql (well probably this is optional but I think its good to compile
it to because Qt3Support may want it on your platform).
Pretty much if you follow the default configure options of Qt4.3.3 you
should be good to go.
Regards
Tim
2008/3/7, Joseph Simantov <joesim2007 at hotmail.com>:
> Hi All,
> Probably slightly off-subject, but since we are mentioning Qt4, I was
> wondering if anybody has installed QGIS on Solaris10. What I'd like to know
> is, what options should be used when compiling Qt4 for use with QGIS.
> Thanks, and Regards,
> Joseph
> ________________________________
> > Subject: AW: [Qgis-developer] Trolltech is Not Porting Qt3Support for
> 64-bit MacBuilds
> > Date: Thu, 6 Mar 2008 22:17:46 +0100
> > From: marco.hugentobler at karto.baug.ethz.ch
> > To: telwertowski at comcast.net; Qgis-developer at lists.osgeo.org
> > CC:
> > Hi Tom,
> > +1 for porting the remaining qt3support code to qt4. My suggestion is to
> open a new branch for this.
> > Regards,
> > Marco
> > -----Ursprüngliche Nachricht-----
> > Von: qgis-developer-bounces at lists.osgeo.org im Auftrag
> von Tom Elwertowski
> > Gesendet: Do 06.03.2008 16:45
> > An: Qgis-developer at lists.osgeo.org
> > Betreff: [Qgis-developer] Trolltech is Not Porting Qt3Support for 64-bit
> MacBuilds
> > Trolltech has released an alpha version of Qt/Mac Cocoa for building
> 64-bit applications. It includes the following note:
> > Qt3Support: At this time we have no plans for making the Qt3Support module
> work with the Qt/Mac Cocoa port in 64-bit mode. Following in footsteps of
> Apple, we would like to encourage you to consider the time of going Cocoa
> and 64-bit as a chance to jettison Qt 3 constructs and classes.
> > Therefore I would like to start converting the remaining QGIS files --
> perhaps 1 to 3 files per work session depending on complexity. Are there any
> issues to be aware of?
> > Since the GRASS plugin contains probably half of the remaining Qt3Support
> usage and QGIS can be built without it, I will not upgrade it until later.
> The immediate goal is to get QGIS to build with Qt/Mac Cocoa.
> > Tom
> > Qgis-developer mailing list
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Rejoignez la nouvelle famille de Windows Live Messenger Cliquez ici!
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
