[Qgis-developer] Re: Connection reusing in postgres provider
Jürgen E. Fischer
jef at norbit.de
Sun Mar 9 18:31:18 EDT 2008
Hi Marco,
On Sun, 09. Mar 2008 at 17:15:56 +0100, Marco Hugentobler wrote:
> There is a problem with the reusage of connections in postgres provider (via
> static member variable QgsPostgresProvider::connections). Two postgres layers
> that share the same connection might influence each others binary cursors. As
> a binary cursors is valid inside a transaction, calling "end work" on a
> connection will also influence the cursor of the second layer.
Right. Either we need a WITH HOLD when declaring the cursor or drop
connection pooling alltogether. The later is probably a necessity
anyway, if we want to introduce feature locking.
I'll try that and Steven's patch tomorrow.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-0
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
