[Qgis-developer] SVG generator patch
Tim Sutton
tim at linfiniti.com
Tue Mar 18 06:29:29 EDT 2008
Hi
+1 from me
for the qt3 to qt4 changes you have in the pipeline, it will be better
to wait till after 0.9.2 release has been branched away from trunk
(which I guess is what you had in mind anyway).
Regards
Tim
On 3/18/08, Tom Elwertowski <telwertowski at comcast.net> wrote:
> 2007/12/17, Steven Bell <botsnlinux at gmail.com>:
> > Attached is a patch which updates the composer to use Qt 4.3's
> QSvgGenerator
> > class. It doesn't fix all of the problems (most notably the fact that
> > layers are not clipped to the map outline), but it is a significant
> > improvement over the Q3Picture SVG generator.
> I propose adding this now for 0.9.2 with preprocessor tests for Qt4.2 and
> 4.3. Users with 4.2 would continue to compile the old code while users of
> 4.3 will benefit from the new code.
> I have already made this modification as part of removing all Qt3 code from
> qgis. The full set of modifications (all except the GRASS plugin) won't be
> ready for about two more weeks but this composer modification is independent
> of everything else. Should I submit it to svn?
> Tom
> Qgis-developer mailing list
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
