[Qgis-developer] SVG generator patch
Marco Hugentobler
marco.hugentobler at karto.baug.ethz.ch
Wed Mar 19 04:12:38 EDT 2008
Hi Tom,
+1
Marco
Am Dienstag 18 März 2008 07:25:54 schrieb Tom Elwertowski:
> 2007/12/17, Steven Bell <botsnlinux at gmail.com>:
> > Attached is a patch which updates the composer to use Qt 4.3's
> > QSvgGenerator class. It doesn't fix all of the problems (most notably
> > the fact that layers are not clipped to the map outline), but it is a
> > significant improvement over the Q3Picture SVG generator.
> I propose adding this now for 0.9.2 with preprocessor tests for Qt4.2 and
> 4.3. Users with 4.2 would continue to compile the old code while users of
> 4.3 will benefit from the new code.
> I have already made this modification as part of removing all Qt3 code from
> qgis. The full set of modifications (all except the GRASS plugin) won't be
> ready for about two more weeks but this composer modification is
> independent of everything else. Should I submit it to svn?
> Tom
> Qgis-developer mailing list
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
