[Qgis-developer] qgis-grass crash
Paolo Cavallini
cavallini at faunalia.it
Tue May 20 09:00:25 EDT 2008
>> Hi all.
>> I'm researching on this nasty bug, crashing qgis when opening a grass
>> vector. I recompiled most of the toolchain from deb-src (from
>> lenny+debian.gfoss.it), and I still get:
> Some further info:
> the crash happens with a custom projection (modified gauss-boaga, thanks
> Markus):
> QGIS SRSID: 100000
> PostGIS SRID: 0
> +proj=tmerc +lat_0=0 +lon_0=9 +k=0.999600 +x_0=1500000 +y_0=0
> +ellps=intl +units=m +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
> qgis does not appear to recognize it, try to use the default projection
> (wgs84 in most cases, the same gauss-boaga): if it finds wgs84 it opens
> the vector (with a wrong projection), if it finds G-B modified it crashes.
I think we caught the bug, thanks to frankie (Lovergine): in
LOCALE=it_IT, points are replaced with commas in the description of
projections, thus qgis does not understand the projections, and grass
plugin crashes.
exopting LANG=C solves the problem, but obviously this should be corrected.
I suggest releasing a 0.10.1 when done.
All the best, and tahnks to jef and niccolo for help.
pc
Paolo Cavallini, see: * http://www.faunalia.it/pc *
