R: [Qgis-developer] Developer/contributor requirements
lami at faunalia.it
lami at faunalia.it
Tue May 20 11:05:27 EDT 2008
Hi Marco,
good work, I will test yor new modules.
With the new svn acccess we will can update the rigth modules for the
release of ver 1.0.
Regards
Leo
> Hi Leo,
> I worked again on the GRASS toolbox; a brief summary:
> New/modified/renamed modules introduced in the previous job:
> - g.region.save
> - g.region.zoom
> - g.region.multiple.raster
> - g.region.multiple.vector
> - r.patch
> - v.patch
> - r.proj
> - r.proj.res
> - v.in.db
> - v.in.ogr
> - v.in.ogr.loc
> - v.in.ogr.all
> - v.in.ogr.all.loc
> - v.in.shape
> - v.in.shape.loc
> see also:
> http://lists.osgeo.org/pipermail/qgis-developer/2008-May/003797.html
> News in the current job:
> I modified descriptions of some g.proj modules (IMHO not correctly
> reflecting the real job of the modules) and added the g.proj.ascii module
> for coherency:
> Module - New description
> g.proj.print - Print projection information of the current location
> g.proj.geo - Print projection information from a georeferenced file
> (raster, vector or image)
> g.proj.ascii - Print projection information from a georeferenced ASCII
> file containing a WKT projection description
> g.proj.proj - Print projection information from a PROJ.4 projection
> description file
> g.proj.geo.new - Print projection information from a georeferenced file
> (raster, vector or image) and create a new location based on it
> g.proj.ascii.new - Print projection information from a georeferenced ASCII
> file containing a WKT projection description and create a new location
> based on it
> g.proj.proj.new - Print projection information from a PROJ.4 projection
> description file and create a new location based on it
> Then I found that the g,proj.region is not included in the default.qgc
> configuration file, and that it is actually an useless module
> As usual, all the mods have been tested on the svn 0.10.0 release code.
> Summarizing, I suggest to test as follows:
> 1. remove g.proj.region (.qgm + .1.png) [not included in
> ./config/default.qgc and actually useless]
> 2. remove g.region (.qgm + .1.png) [replaced by g.proj.save]
> 3. remove g.proj.print.2.png [according to the new ./config/default.qgc
> layout, where I *normalized* the tree]
> 4. add the new modules (extract the zip to ../src/plugins/grass/modules
> and modify the ./config/default.qgc patching the svn qgis-trunk diff
> attached]
> Best regards,
> Marco
