[Qgis-developer] Can't Enable on the fly projection
Guy Roussin guy.roussin at teledetection.fr
Mon May 26 08:37:38 EDT 2008
Niccolo Rigacci a écrit :
>> I get qgis 0.10.0 from debian.gfoss.it and i can't enable
>> on the fly projection even if i click on the checkbox.
>> I get this kind of messages when i run qgis from a terminal :
>> $ qgis
>> Warning: No valid projection. Unable to set map units.
> There are some problem with the package made by me.
> If you have installed libgdal1-1.5.0-grass make a symbolic link
>   ln -s gdal15plugins /usr/lib/gdalplugins
> Then there is a problem with projection and Qgis locales, try to
> start QGIS after setting the $LANG variable:
> export LANG=en_US.UTF-8; qgis
> The bug will be fixed in QGIS.
Thank you Niccolo, works fine now.
Guy Roussin
