R: [Qgis-developer] GRASS Toolbox list view patch
Tim Sutton
tim at linfiniti.com
Tue May 27 20:55:57 EDT 2008
Hi Marco
Thanks for the feedback. I will try to build under msvc here and see
if I can address the issues with the plugin manager. I think Radim
specifically expanded the tree in the grass toolbox because you can
access each tool with a single click. Perhaps we can add some
collapse all / expand all buttons to the toolbox to support both
people who prefer it expanded and those who prefer it collapsed. Ill
look into this.
I tested the plugin manager with my msvc build and will commit a fix
in a few minutes that should sort out the issue you were having.
Regards
Tim
Em May 26, 2008, às 4:52 PM, Marco Pasetti escreveu:
> Hi Tim,
> I built the latest svn trunk with your patch on windows (xp for the
> moment,
> on the next days also on Vista)
> 1. the idea for the grass toolbox is good (I mean the module list
> with the
> run-time type filter/search), but I think that:
> 1.1. we should start the grass toolbox tree collapsed instead of fully
> expanded
> 1.2. the font of the module tiltles should be a little bit smaller
> 1.3. the module list tab still has some render problems
> 1.4. I cannot select (that means start) the filtered modules
> 2. I have big rendering and selecting (check-boxes) problems with
> the plugin
> manager
> Sorry, I have no such spare time to make deeper analisys :-(
> All the best
> Marco
> -----Messaggio originale-----
> Da: qgis-developer-bounces at lists.osgeo.org
> [mailto:qgis-developer-bounces at lists.osgeo.org] Per conto di Tim
> Sutton
> Inviato: lunedì 26 maggio 2008 17.37
> A: qgis-developer at lists.osgeo.org
> Oggetto: [Qgis-developer] GRASS Toolbox list view patch
> Hi Folks
> Here is my first pass at a grass filtered list view for grass toolbox
> (attached patch). There are still a few issues:
> - checkboxes next to items need to be removed
> - filter box below list needs a label
> - some funny rendering happens on tab background on start up,
> just click
> to another tab and then back to the list view
> I've been thinking that it might be better to implement this 'as-
> well- as'
> the existing tree view, so that if you want to browse the tools by
> heirachy
> you still can, or if you want to quickly get all the tools that
> e.g. work
> with ascii, you can just type 'ascii' in the filter box and be on
> your way.
> Anyway, will be interesting to get feedback from heavy grass users
> is the
> list box approach makes life easier or not. To apply the patch, go
> to the
> qgis top level dir and do:
> patch -p0 < grass_detailed_list_patch.diff
> You need to be using a current svn checkout for it to work properly
> (r8522 or better).
> Regards
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
