[Qgis-developer] QGIS Python support in a library
John C. Tull
john.tull at wildnevada.org
Wed May 28 13:06:34 EDT 2008
I don't know if this is related to linking issues that William has
brought up in the past, but it's a possibility. William can provide
the best input from the Mac dev side, as far as I know.
Regards,
John
On May 28, 2008, at 9:45 AM, Tim Sutton wrote:
> Hi
> I tested under Ubuntu with r8535 and everything builds fine so it
> seems mac specific.
> Regards
> Tim
> 2008/5/28 John C. Tull <john.tull at wildnevada.org>:
>> I had a similar failure in most r8535:
>> [ 67%] Building CXX object
>> src/python/CMakeFiles/qgispython.dir/qgspythonutilsimpl.o
>> Linking CXX shared library libqgispython.dylib
>> Undefined symbols:
>> "QgsApplication::pkgDataPath()", referenced from:
>> QgsPythonUtilsImpl::pythonPath() in qgspythonutilsimpl.o
>> "QgsMessageOutput::createMessageOutput()", referenced from:
>> QgsPythonUtilsImpl::runString(QString const&, QString)in
>> "QgsApplication::qgisSettingsDirPath()", referenced from:
>> QgsPythonUtilsImpl::homePluginsPath() in
>> ld: symbol(s) not found
>> collect2: ld returned 1 exit status
>> make[2]: *** [src/python/libqgispython.0.11.dylib] Error 1
>> make[1]: *** [src/python/CMakeFiles/qgispython.dir/all] Error 2
>> make: *** [all] Error 2
>> John
>> On May 28, 2008, at 8:54 AM, Tim Sutton wrote:
>>> Hi Martin
>>> Thanks for doing this change - I think it will be a nice
>>> improvement.
>>> For me I get this error when trying to build on OSX:
>>> [ 72%] Built target python
>>> Linking CXX executable qgis_help.app/Contents/MacOS/qgis_help
>>> [ 74%] Built target qgis_help
>>> ld: Undefined symbols:
>>> __ZN14QgsApplication11pkgDataPathEv
>>> __ZN14QgsApplication19qgisSettingsDirPathEv
>>> __ZN16QgsMessageOutput19createMessageOutputEv
>>> __ZN9QgsLogger5debugERK7QStringiPKcS4_i
>>> /usr/libexec/gcc/i686-apple-darwin8/4.0.1/libtool: internal link
>>> edit
>>> command failed
>>> /usr/libexec/gcc/powerpc-apple-darwin8/4.0.1/libtool: internal link
>>> edit command failed
>>> lipo: can't figure out the architecture type of: /var/tmp//
>>> cc9EZSsS.out
>>> Regards
>>> Tim
>>> 2008/5/28 Martin Dobias <wonder.sk at gmail.com>:
>>>> Hi all,
>>>> as you probably know, until now embedding of Python to QGIS was
>>>> done
>>>> directly in the QGIS application sources and the support was
>>>> implemented using conditional #ifdefs. So when building qgis
>>>> binary,
>>>> you got it with or without python. This wasn't a very good solution
>>>> and was doing problems for packagers since there was no easy way
>>>> to do
>>>> optional installation of python support.
>>>> In my recent commit to trunk (r8530) I've done the embedding in
>>>> more
>>>> flexible way. All python support code has been moved to src/python
>>>> directory and now compiles as "qgispython" library. When QGIS
>>>> application is started, it checks for the presence of this
>>>> library and
>>>> tries to load it and init python support. If something is wrong,
>>>> the
>>>> python support (i.e. python plugins and console) is disabled.
>>>> I've tested this new approach on my ubuntu box with success, but
>>>> other
>>>> platforms are untested (I could try it on win, but I don't have
>>>> access
>>>> to OS X). So Mac and Win wizards please give it a try to see
>>>> whether
>>>> it's working fine there or not. I know that Mac makes difference
>>>> between shared objects and libraries (MODULE / SHARED option in
>>>> CMake)
>>>> but I have no idea which one to choose there so try changing this
>>>> first if you encounter some problems.
>>>> Generally I hope it won't produce any great havoc, but one never
>>>> knows
>>>> :-) If that works fine, you shouldn't notice any change. If that
>>>> doesn't work fine, nothing python-related will work. Additionally,
>>>> this change has no impact on python bindings or plugins.
>>>> Regards,
>>>> Martin
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Tim Sutton
>>> QGIS Project Steering Committee Member - Release Manager
>>> Visit http://qgis.org for a great open source GIS
>>> openModeller Desktop Developer
>>> Visit http://openModeller.sf.net for a great open source ecological
>>> niche modelling tool
>>> Home Page: http://tim.linfiniti.com
>>> Skype: timlinux
>>> Irc: timlinux on #qgis at freenode.net
> Tim Sutton
> Skype: timlinux
