[Qgis-developer] Mapserver Exporter Bug?
John C. Tull
john.tull at wildnevada.org
Thu May 29 16:18:24 EDT 2008
I get the same error on OS X, but the suggested change to line 81 did
not fix this for me.
John
On May 27, 2008, at 3:42 PM, Mauricio de Paulo wrote:
> Hi everybody,
> I was working with mapserver exporter and ran into a problem with
> the error
> message at the end of this mail.
> After a little debug i found out that the code was passing a QString
> instead
> of a python string when reading the filename from the dialog. This
> is a
> regular source of bug as some classes don't understand QStrings very
> well,
> even though they do work a lot like python strings.
> After the change on mapserverexport.py on line 81:
> exporter = Qgis2Map(str(self.dlg.ui.txtQgisFilePath.text()),
> str(self.dlg.ui.txtMapFilePath.text()))
> I don't know exactly if only my python and pyqt versions require
> this but it
> fixed the problem for me. I think it's a good idea to NEVER work with
> QString, just with python strings for compatibility purposes.
> versions:
> Python 2.5.2
> PyQt4.QtCore.qVersion() '4.3.4'
> qgis 0.10.0
> Ubuntu 8.10
> Thanks for the good work with Mapserver Export Plugin. I've been
> working with
> it for 2 years now and it fills a great gap in the mapfile production.
> Maurício de Paulo
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File "/home/vatto/.qgis//python/plugins/mapserver_export/
> mapserverexport.py",
> line 81, in run
> exporter = Qgis2Map(self.dlg.ui.txtQgisFilePath.text(),
> ms_export.py", line
> 37, in __init__
> self.qgs = minidom.parse(projectFile)
> File "/usr/lib/python2.5/xml/dom/minidom.py", line 1915, in parse
> return expatbuilder.parse(file)
> File "/usr/lib/python2.5/xml/dom/expatbuilder.py", line 928, in parse
> result = builder.parseFile(file)
> File "/usr/lib/python2.5/xml/dom/expatbuilder.py", line 204, in
> parseFile
> buffer = file.read(16*1024)
> AttributeError: read
> W
> Qgis-developer mailing list
