[Qgis-developer] Mapserver Exporter Bug?
Mauricio de Paulo
mauricio.dev at gmail.com
Thu May 29 18:38:52 EDT 2008
Please, can you test this mapserverexport update? I've written the str()
function on every qwidget that might need the type cast. And i did some other
fix that i don't remember (hum... i think that it was the exporter wrong
layers' ordering)
Hope it works.
See ya.
Maurício de Paulo
On Thursday 29 May 2008 17:18:24 John C. Tull wrote:
> I get the same error on OS X, but the suggested change to line 81 did
> not fix this for me.
> John
> On May 27, 2008, at 3:42 PM, Mauricio de Paulo wrote:
> > Hi everybody,
> > I was working with mapserver exporter and ran into a problem with
> > the error
> > message at the end of this mail.
> > After a little debug i found out that the code was passing a QString
> > instead
> > of a python string when reading the filename from the dialog. This
> > is a
> > regular source of bug as some classes don't understand QStrings very
> > well,
> > even though they do work a lot like python strings.
> > After the change on mapserverexport.py on line 81:
> > exporter = Qgis2Map(str(self.dlg.ui.txtQgisFilePath.text()),
> > str(self.dlg.ui.txtMapFilePath.text()))
> > I don't know exactly if only my python and pyqt versions require
> > this but it
> > fixed the problem for me. I think it's a good idea to NEVER work with
> > QString, just with python strings for compatibility purposes.
> > versions:
> > Python 2.5.2
> > PyQt4.QtCore.qVersion() '4.3.4'
> > qgis 0.10.0
> > Ubuntu 8.10
> > Thanks for the good work with Mapserver Export Plugin. I've been
> > working with
> > it for 2 years now and it fills a great gap in the mapfile production.
> > Maurício de Paulo
> > An error has occured while executing Python code:
> > Traceback (most recent call last):
> > File "/home/vatto/.qgis//python/plugins/mapserver_export/
> > mapserverexport.py",
> > line 81, in run
> > exporter = Qgis2Map(self.dlg.ui.txtQgisFilePath.text(),
> > ms_export.py", line
> > 37, in __init__
> > self.qgs = minidom.parse(projectFile)
> > File "/usr/lib/python2.5/xml/dom/minidom.py", line 1915, in parse
> > return expatbuilder.parse(file)
> > File "/usr/lib/python2.5/xml/dom/expatbuilder.py", line 928, in parse
> > result = builder.parseFile(file)
> > File "/usr/lib/python2.5/xml/dom/expatbuilder.py", line 204, in
> > parseFile
> > buffer = file.read(16*1024)
> > AttributeError: read
> > W
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Type: application/x-python
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20080529/4c685588/mapserverexport.bin
