[Qgis-developer] Mapserver Exporter Bug?
John C. Tull
john.tull at wildnevada.org
Thu May 29 19:06:27 EDT 2008
Mauricio,
I get the following error now, but this may be related to some layers
with no names because a partial file is being written. Let me play
some more...
An error has occured while executing Python code:
File "/Users/jctull/.qgis//python/plugins/mapserver_export/
mapserverexport.py", line 94, in run
result = exporter.writeMapFile()
ms_export.py", line 101, in writeMapFile
self.writeMapLayers()
ms_export.py", line 283, in writeMapLayers
self.outFile.write(" NAME '" +
lyr.getElementsByTagName("layername")
[0].childNodes[0].nodeValue.encode('utf-8').replace("\"", "") + "'\n")
IndexError: list index out of range
Ok, this is because there were some layers (rasters) that had no name.
When I drag and drop rasters, they come in with no name, but I place
them in a group folder, so never change them. This led to the above
problem.
John
On May 29, 2008, at 3:38 PM, Mauricio de Paulo wrote:
> Please, can you test this mapserverexport update? I've written the
> str()
> function on every qwidget that might need the type cast. And i did
> some other
> fix that i don't remember (hum... i think that it was the exporter
> wrong
> layers' ordering)
> Hope it works.
> See ya.
> Maurício de Paulo
> On Thursday 29 May 2008 17:18:24 John C. Tull wrote:
>> I get the same error on OS X, but the suggested change to line 81 did
>> not fix this for me.
>> John
>> On May 27, 2008, at 3:42 PM, Mauricio de Paulo wrote:
>>> Hi everybody,
>>> I was working with mapserver exporter and ran into a problem with
>>> the error
>>> message at the end of this mail.
>>> After a little debug i found out that the code was passing a QString
>>> instead
>>> of a python string when reading the filename from the dialog. This
>>> is a
>>> regular source of bug as some classes don't understand QStrings very
>>> well,
>>> even though they do work a lot like python strings.
>>> After the change on mapserverexport.py on line 81:
>>> exporter = Qgis2Map(str(self.dlg.ui.txtQgisFilePath.text()),
>>> str(self.dlg.ui.txtMapFilePath.text()))
>>> I don't know exactly if only my python and pyqt versions require
>>> this but it
>>> fixed the problem for me. I think it's a good idea to NEVER work
>>> with
>>> QString, just with python strings for compatibility purposes.
>>> versions:
>>> Python 2.5.2
>>> PyQt4.QtCore.qVersion() '4.3.4'
>>> qgis 0.10.0
>>> Ubuntu 8.10
>>> Thanks for the good work with Mapserver Export Plugin. I've been
>>> working with
>>> it for 2 years now and it fills a great gap in the mapfile
>>> production.
>>> Maurício de Paulo
>>> File "/home/vatto/.qgis//python/plugins/mapserver_export/
>>> line 81, in run
>>> exporter = Qgis2Map(self.dlg.ui.txtQgisFilePath.text(),
>>> ms_export.py", line
>>> 37, in __init__
>>> self.qgs = minidom.parse(projectFile)
>>> File "/usr/lib/python2.5/xml/dom/minidom.py", line 1915, in parse
>>> return expatbuilder.parse(file)
>>> File "/usr/lib/python2.5/xml/dom/expatbuilder.py", line 928, in
>>> parse
>>> result = builder.parseFile(file)
>>> File "/usr/lib/python2.5/xml/dom/expatbuilder.py", line 204, in
>>> parseFile
>>> buffer = file.read(16*1024)
>>> AttributeError: read
>>> W
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> <mapserverexport.py>
