[Qgis-developer] Re: grass plugin + python
Byambaa Mendbayar
mendbayar_b at mongol.net
Tue Nov 11 05:17:15 EST 2008
Dear Tim and Martin,
Thank you very much, both of my problems are now working fine after I
have remove older versions of QGIS.
With best regards,
B. Mendbayar
P.S Tim my first name is Mendbayar, last name is Byambaa, therefore
please call me Mendbayar or shortly Mendee. Thanks again.
On Mon, 2008-11-10 at 22:11 +0200, Tim Sutton wrote:
> Hi Byambaa
> I dont know if this will help but if you have older (<= 0.11) versions
> of QGIS on your system, you could try removing them.
> Regards
> Tim
> On Tue, 2008-11-11 at 01:17 +0800, Byambaa Mendbayar wrote:
> > Dear developers,
> > I have compiled latest svn head and to run QGIS after that I have get
> > following from console which is load grass plugin.
> > Debug: /home/bmendbayar/development/qgis/src/core/qgsproviderregistry.cpp: 195: (QgsProviderRegistry) Checking /home/bmendbayar/development/qgis/apps/lib/qgis/libgrassprovider.so : ...invalid (lib not loadable)
> > How to load grass plugin in QGIS? (Of course my compilation and linking
> > was successful)
> > By the way I have also get one pop-up window which is titled "Python
> > error" context is following:
> > Couldn't load PyQGIS.
> > Python support will be disabled.
> > Traceback (most recent call last):
> > File "", line 1, in
> > ImportError: No module named qgis.core
> > Python version:
> > 2.5.2 (r252:60911, Jun 7 2008, 00:38:48)
> > [GCC 4.3.1 20080507 (prerelease) [gcc-4_3-branch revision 135036]]
> > Python path:
> > ['/python', '/home/bmendbayar/.qgis//python/plugins', '/python/plugins',
> > '/usr/lib/python25.zip', '/usr/lib64/python2.5',
> > '/usr/lib64/python2.5/plat-linux2', '/usr/lib64/python2.5/lib-tk',
> > '/usr/lib64/python2.5/lib-dynload',
> > '/usr/lib64/python2.5/site-packages',
> > '/usr/lib64/python2.5/site-packages/Numeric',
> > '/usr/lib64/python2.5/site-packages/PIL',
> > '/usr/lib64/python2.5/site-packages/gtk-2.0',
> > '/usr/local/lib64/python2.5/site-packages',
> > '/usr/local/lib64/python2.5/site-packages/wx-2.8-gtk2-unicode']
> > How can I enable it?
> > Thanks and best regards,
> > B. Mendbayar
