[Qgis-developer] Re: grass plugin + python
    Tim Sutton
    tim at linfiniti.com
    Tue Nov 11 05:43:18 EST 2008
Hi Mendee
2008/11/11 Byambaa Mendbayar <mendbayar_b at mongol.net>:
> Dear Tim and Martin,
> Thank you very much, both of my problems are now working fine after I
> have remove older versions of QGIS.
Glad its working now.
> With best regards,
> B. Mendbayar
> P.S Tim my first name is Mendbayar, last name is Byambaa, therefore
> please call me Mendbayar or shortly Mendee. Thanks again.
I think you mentioned this before - my apologies I will try to
remember. It will probably help if you set your email client to sign
your emails as Mendbayar Byambaa rather than Byambaa Mendbayar as it
currently does.
Regards
Tim
> On Mon, 2008-11-10 at 22:11 +0200, Tim Sutton wrote:
>> Hi Byambaa
>> I dont know if this will help but if you have older (<= 0.11) versions
>> of QGIS on your system, you could try removing them.
>> Regards
>> Tim
>> On Tue, 2008-11-11 at 01:17 +0800, Byambaa Mendbayar wrote:
>> > Dear developers,
>> > I have compiled latest svn head and to run QGIS after that I have get
>> > following from console which is load grass plugin.
>> > Debug: /home/bmendbayar/development/qgis/src/core/qgsproviderregistry.cpp: 195: (QgsProviderRegistry) Checking  /home/bmendbayar/development/qgis/apps/lib/qgis/libgrassprovider.so : ...invalid (lib not loadable)
>> > How to load grass plugin in QGIS? (Of course my compilation and linking
>> > was successful)
>> > By the way I have also get one pop-up window which is titled "Python
>> > error" context is following:
>> > Couldn't load PyQGIS.
>> > Python support will be disabled.
>> > Traceback (most recent call last):
>> >   File "", line 1, in
>> > ImportError: No module named qgis.core
>> > Python version:
>> > 2.5.2 (r252:60911, Jun  7 2008, 00:38:48)
>> > [GCC 4.3.1 20080507 (prerelease) [gcc-4_3-branch revision 135036]]
>> > Python path:
>> > ['/python', '/home/bmendbayar/.qgis//python/plugins', '/python/plugins',
>> > '/usr/lib/python25.zip', '/usr/lib64/python2.5',
>> > '/usr/lib64/python2.5/plat-linux2', '/usr/lib64/python2.5/lib-tk',
>> > '/usr/lib64/python2.5/lib-dynload',
>> > '/usr/lib64/python2.5/site-packages',
>> > '/usr/lib64/python2.5/site-packages/Numeric',
>> > '/usr/lib64/python2.5/site-packages/PIL',
>> > '/usr/lib64/python2.5/site-packages/gtk-2.0',
>> > '/usr/local/lib64/python2.5/site-packages',
>> > '/usr/local/lib64/python2.5/site-packages/wx-2.8-gtk2-unicode']
>> > How can I enable it?
>> > Thanks and best regards,
>> > B. Mendbayar
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
