[Qgis-developer] libgdal1.5
    Jürgen E. Fischer
    jef at norbit.de
    Thu Nov 13 13:04:11 EST 2008
Hi Emmanuel,
On Thu, 13. Nov 2008 at 17:51:15 +0100, Poizot Emmanuel wrote:
> I just upgrade my os from Ubuntu 8.04 to 8.10. In this latter version,
> libgdal is in it's 1.5 version.
> I made an update also from trunck of QGIS sources and recompile it. I
> had to make a symbolic link libgdal1.4.0.so to libgdal1.5.0.so.1.12.2 to
> get it compile.
Check if your libgdal1-dev also was upgraded.   Even in that case you'll
probably run into a GDAL bug.  We have a gdal package ported from debian
to ubuntu intrepid that contains a fix for that.
> But at run time QGIS crash, because of libgdal1.5. (I did a "gbd qgis"
> and "run" discovering it crashed on that library)
> How can I resolved that ?
You should also upgrade your libgdal1-dev package to 1.5. There
shouldn't be a need to symlink.
And finally there are yesterday's packages of trunk on
https://launchpad.net/~jef-norbit - so you could also get away without
compiling.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
