AW: [Qgis-developer] Georeferencer-GDAL
Hugentobler Marco
marco.hugentobler at karto.baug.ethz.ch
Sun Nov 16 15:13:31 EST 2008
Hi Maxim
Cool stuff, thanks a lot!
Since we are in feature freeze for 1.0, I added it as a ticket to track (#1404). I'm happy to apply it to svn trunk after 1.0 is out.
Regards,
Marco
-----Ursprüngliche Nachricht-----
Von: qgis-developer-bounces at lists.osgeo.org im Auftrag von Maxim Dubinin
Gesendet: So 16.11.2008 18:29
An: qgis-developer at lists.osgeo.org
Betreff: [Qgis-developer] Georeferencer-GDAL
Hi all,
I'm happy to announce, that we modified Georeferencer
extension and want other developers to try it out sometime (I know
we're in freeze, but we needed this functionality). We did some testing on Preview2 and everything works really well (except annoying potentiall
GDAL bug with 6 points in 2nd order polynomial, which is being discussed in its
trac right now).
What we did: we've added the ability to use 1-2-3rd order polynomials
via GDAL functions to transform rasters.
Why: Helmert transform performance implemented before was
sub-suboptimal
How: Built ontop of existing Georeferencer extension (basically added
three new transforms to the list)
Next: We're doing some more modifications of Georeferener, but they're
minor.
Here is svn for this beauty: http://svn.gis-lab.info/qgis-gdal-georef/
Maxim
http://gis-lab.info
?? ?????? 16 ?????? 2008 ?., 9:49:05:
TS> Hi
TS> Usually cmake is good about determining when stuff needs a recompile.
TS> However if it doesnt pick up something try just running cmake or ccmake
TS> again and then compiling. As a last resort use make clean.
TS> Remember that we are in GUI freeze so small tweaks like you have made we
TS> can probably get away with, but do try to avoid changing any visual
TS> parts of the application otherwise you will frustrate the document
TS> writers.
TS> Regards
TS> Tim
TS> On Sun, 2008-11-16 at 16:21 +0100, Borys Jurgiel wrote:
>> Hi list,
>> I've fixed the .ui file of dxf2shpconverter plugin but I need to `make clean`
>> in order to recompile it. Is there any way to force recompiling? If not,
>> please remember to make clean before building future packages :)
>> Regards,
>> B.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
