[Qgis-developer] Georeferencer-GDAL
Maxim Dubinin sim at gis-lab.info
Tue Nov 18 00:03:45 EST 2008
Georeferencer plugin again.
We've added TPS transformation from GDAL, modified dialog windows
little bit and thinking about removing one of the windows (smaller one)
completely to reduce unneccesary clutter. Everything will fit nicely
on a single window.
Is there anyone who thinks this is a bad idea? May be original
Georeferencer author? Let me know.
Maxim
Вы писали 16 ноября 2008 г., 11:29:39:
MD> Hi all,
MD> I'm happy to announce, that we modified Georeferencer
MD> extension and want other developers to try it out sometime (I know
MD> we're in freeze, but we needed this functionality). We did some
MD> testing on Preview2 and everything works really well (except annoying potentiall
MD> GDAL bug with 6 points in 2nd order polynomial, which is being discussed in its
MD> trac right now).
MD> What we did: we've added the ability to use 1-2-3rd order polynomials
MD> via GDAL functions to transform rasters.
MD> Why: Helmert transform performance implemented before was
MD> sub-suboptimal
MD> How: Built ontop of existing Georeferencer extension (basically added
MD> three new transforms to the list)
MD> Next: We're doing some more modifications of Georeferener, but they're
MD> minor.
MD> Here is svn for this beauty: http://svn.gis-lab.info/qgis-gdal-georef/
MD> Maxim
MD> http://gis-lab.info
MD> Вы писали 16 ноября 2008 г., 9:49:05:
TS>> Hi
TS>> Usually cmake is good about determining when stuff needs a recompile.
TS>> However if it doesnt pick up something try just running cmake or ccmake
TS>> again and then compiling. As a last resort use make clean.
TS>> Remember that we are in GUI freeze so small tweaks like you have made we
TS>> can probably get away with, but do try to avoid changing any visual
TS>> parts of the application otherwise you will frustrate the document
TS>> writers.
TS>> Regards
TS>> Tim
TS>> On Sun, 2008-11-16 at 16:21 +0100, Borys Jurgiel wrote:
>>> Hi list,
>>> I've fixed the .ui file of dxf2shpconverter plugin but I need to `make clean`
>>> in order to recompile it. Is there any way to force recompiling? If not,
>>> please remember to make clean before building future packages :)
>>> Regards,
>>> B.
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
MD> _______________________________________________
MD> Qgis-developer mailing list
MD> Qgis-developer at lists.osgeo.org
MD> http://lists.osgeo.org/mailman/listinfo/qgis-developer
