[Qgis-developer] Georeferencer-GDAL
Tim Sutton
tim at linfiniti.com
Tue Nov 18 12:01:27 EST 2008
Hi Maxim
On Mon, 2008-11-17 at 23:03 -0600, Maxim Dubinin wrote:
> Georeferencer plugin again.
> We've added TPS transformation from GDAL, modified dialog windows
> little bit and thinking about removing one of the windows (smaller one)
> completely to reduce unneccesary clutter. Everything will fit nicely
> on a single window.
Sounds great!
> Is there anyone who thinks this is a bad idea? May be original
> Georeferencer author? Let me know.
Lars (the original author) is no longer active in the project. I was
going to suggest you volunteer to be its new maintainer since you are
interested in it!
Regards
Tim
> Maxim
> Вы писали 16 ноября 2008 г., 11:29:39:
> MD> Hi all,
> MD> I'm happy to announce, that we modified Georeferencer
> MD> extension and want other developers to try it out sometime (I know
> MD> we're in freeze, but we needed this functionality). We did some
> MD> testing on Preview2 and everything works really well (except annoying potentiall
> MD> GDAL bug with 6 points in 2nd order polynomial, which is being discussed in its
> MD> trac right now).
> MD> What we did: we've added the ability to use 1-2-3rd order polynomials
> MD> via GDAL functions to transform rasters.
> MD> Why: Helmert transform performance implemented before was
> MD> sub-suboptimal
> MD> How: Built ontop of existing Georeferencer extension (basically added
> MD> three new transforms to the list)
> MD> Next: We're doing some more modifications of Georeferener, but they're
> MD> minor.
> MD> Here is svn for this beauty: http://svn.gis-lab.info/qgis-gdal-georef/
> MD> Maxim
> MD> http://gis-lab.info
> MD> Вы писали 16 ноября 2008 г., 9:49:05:
> TS>> Hi
> TS>> Usually cmake is good about determining when stuff needs a recompile.
> TS>> However if it doesnt pick up something try just running cmake or ccmake
> TS>> again and then compiling. As a last resort use make clean.
> TS>> Remember that we are in GUI freeze so small tweaks like you have made we
> TS>> can probably get away with, but do try to avoid changing any visual
> TS>> parts of the application otherwise you will frustrate the document
> TS>> writers.
> TS>> Regards
> TS>> Tim
> TS>> On Sun, 2008-11-16 at 16:21 +0100, Borys Jurgiel wrote:
> >>> Hi list,
> >>> I've fixed the .ui file of dxf2shpconverter plugin but I need to `make clean`
> >>> in order to recompile it. Is there any way to force recompiling? If not,
> >>> please remember to make clean before building future packages :)
> >>> Regards,
> >>> B.
> >>> _______________________________________________
> >>> Qgis-developer mailing list
> >>> Qgis-developer at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> MD> _______________________________________________
> MD> Qgis-developer mailing list
> MD> Qgis-developer at lists.osgeo.org
> MD> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Visit http://linfiniti.com to find out about:
* QGIS programming services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting & Support Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20081118/e6fe3514/attachment.bin
