[Qgis-developer] Georeferencer-GDAL
Byambaa Mendbayar mendbayar_b at mongol.net
Tue Nov 18 00:56:31 EST 2008
Hello Maxim,
Thank you very much for you work.
Yesterday I have compile and test your modified Georeferencer plugin in
my workstation (openSUSE 11.0 x86_64). It have been working for me to
geo-reference my plain rasters.
Today I want to compile it on windows (actually on my Virtual Box)
combining latest QGIS svn head (qgis-gdal-georef revision 26, qgis
revision 9661). But I have get errors! Error message is following:
[ 96%] Built target ogrconverterplugin
Linking CXX shared module libgeorefplugin.dll
CMakeFiles/georefplugin.dir/moc_qgspointdialog.obj:moc_qgspointdialog.cxx:(.text
+0x163): undefined reference to
`QgsPointDialog::on_pbnSelectWorldFile_clicked()
+0x189): undefined reference to
`QgsPointDialog::on_pbnGenerateWorldFile_clicked
collect2: ld returned 1 exit status
mingw32-make[2]: *** [src/plugins/qgis-gdal-georef/libgeorefplugin.dll]
Error 1
mingw32-make[1]: ***
[src/plugins/qgis-gdal-georef/CMakeFiles/georefplugin.dir/a
ll] Error 2
mingw32-make: *** [all] Error 2
C:\msys\local\src\qgisTrunk\build>
What's wrong there? Can you help to me?
With best regards,
B.Mendbayar
On Sun, 2008-11-16 at 11:29 -0600, Maxim Dubinin wrote:
> Hi all,
> I'm happy to announce, that we modified Georeferencer
> extension and want other developers to try it out sometime (I know
> we're in freeze, but we needed this functionality). We did some testing on Preview2 and everything works really well (except annoying potentiall
> GDAL bug with 6 points in 2nd order polynomial, which is being discussed in its
> trac right now).
> What we did: we've added the ability to use 1-2-3rd order polynomials
> via GDAL functions to transform rasters.
> Why: Helmert transform performance implemented before was
> sub-suboptimal
> How: Built ontop of existing Georeferencer extension (basically added
> three new transforms to the list)
> Next: We're doing some more modifications of Georeferener, but they're
> minor.
> Here is svn for this beauty: http://svn.gis-lab.info/qgis-gdal-georef/
> Maxim
> http://gis-lab.info
> Вы писали 16 ноября 2008 г., 9:49:05:
> TS> Hi
> TS> Usually cmake is good about determining when stuff needs a recompile.
> TS> However if it doesnt pick up something try just running cmake or ccmake
> TS> again and then compiling. As a last resort use make clean.
> TS> Remember that we are in GUI freeze so small tweaks like you have made we
> TS> can probably get away with, but do try to avoid changing any visual
> TS> parts of the application otherwise you will frustrate the document
> TS> writers.
> TS> Regards
> TS> Tim
> TS> On Sun, 2008-11-16 at 16:21 +0100, Borys Jurgiel wrote:
> >> Hi list,
> >> I've fixed the .ui file of dxf2shpconverter plugin but I need to `make clean`
> >> in order to recompile it. Is there any way to force recompiling? If not,
> >> please remember to make clean before building future packages :)
> >> Regards,
> >> B.
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
