[Qgis-developer] Re: [QGIS Commit] r9685 -
trunk/qgis/src/core/renderer
Maciej Sieczka
msieczka at sieczka.org
Sun Nov 23 04:01:24 EST 2008
svn_qgis at osgeo.org pisze:
> Author: timlinux Date: 2008-11-22 16:36:44 -0500 (Sat, 22 Nov 2008)
> New Revision: 9685
> Modified: trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.cpp
> Log: Use 0.1 for default line width instead of 0.4
2 things regarding this change:
1. Currently "Continous color" uses a different outline width than the
other legend types. Shouldn't all use the same?
2. I suggest to default to 0.2 or so rather than 0.1. It's to small for
PDF output. At least on my 1280x800 LCD 0.1 looks bad. 0.2 on the main
map cnavas looks as good as 0.1 and in the PDF output it is much more
readable, while still not too thick.
Maciek
Maciej Sieczka
www.sieczka.org
