[Qgis-developer] Re: [QGIS Commit] r9685 -
	trunk/qgis/src/core/renderer
    Tim Sutton
    tim at linfiniti.com
    Sun Nov 23 09:47:15 EST 2008
Hi
On Sun, 2008-11-23 at 10:01 +0100, Maciej Sieczka wrote:
> svn_qgis at osgeo.org pisze:
> > Author: timlinux Date: 2008-11-22 16:36:44 -0500 (Sat, 22 Nov 2008)
> > New Revision: 9685
> > Modified: trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.cpp
> > Log: Use 0.1 for default line width instead of 0.4
> 2 things regarding this change:
> 1. Currently "Continous color" uses a different outline width than the
> other legend types. Shouldn't all use the same?
Yes I agree they should....just need to find where this is happening and
I'll set it to 0.2 too. One day I'll make default line widths user
configurable I guess...
> 2. I suggest to default to 0.2 or so rather than 0.1. It's to small for
> PDF output. At least on my 1280x800 LCD 0.1 looks bad. 0.2 on the main
> map cnavas looks as good as 0.1 and in the PDF output it is much more
> readable, while still not too thick.
Done with r9686
Regards
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting & Support Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20081123/f03fabb3/attachment.bin
