[Qgis-developer] Re: [QGIS Commit] r9685 -
trunk/qgis/src/core/renderer
Maciej Sieczka
msieczka at sieczka.org
Mon Nov 24 17:05:03 EST 2008
Tim Sutton pisze:
> On Sun, 2008-11-23 at 10:01 +0100, Maciej Sieczka wrote:
>> 1. Currently "Continous color" uses a different outline width than
>> the other legend types. Shouldn't all use the same?
> Yes I agree they should....just need to find where this is happening
> and I'll set it to 0.2 too. One day I'll make default line widths
> user configurable I guess...
>> 2. I suggest to default to 0.2 or so rather than 0.1. It's to small
>> for PDF output. At least on my 1280x800 LCD 0.1 looks bad. 0.2 on
>> the main map cnavas looks as good as 0.1 and in the PDF output it
>> is much more readable, while still not too thick.
> Done with r9686
Thanks Tim for looking into this. Now there are 3 different default
width settings - "Unique Value" uses 0.1, "Continous color" 0.4 and the
other two 0.2 as I suggested. Please unify this id possible. Thanks again.
Maciek
Maciej Sieczka
www.sieczka.org
