[Qgis-developer] plug ins- how to start
    Richard Duivenvoorde
    rdmailings at duif.net
    Thu Oct 16 03:38:10 EDT 2008
Hi Elizabeth,
as Paolo mentioned, the standard Postgis layer (Layer / Add a Postgis
layer) makes it possible to connect to postgis, view the geometries AND
view/edit/save the attribute data.
If that's what you want, you're done :-)
But if you just want to write some code /plugin for qgis, go ahead.
You can either write your plugin in cpp (which is/was the normal way
pre-0.8 or so). The Copyrightlabel, GPS Tools etc are written in cpp.
But you will need a full cpp build environment (which I think is a
little easier to make in ubuntu (???)).
In my opinion, the easiest way to write a plugin is in python. Search
the wiki for python plugin:
http://wiki.qgis.org/qgiswiki/PluginRepositories?action=fullsearch&context=180&value=python+plugin&fullsearch=Text
I think http://wiki.qgis.org/qgiswiki/DevelopingPluginsWithPython is a
good page to start :-)
In this way you do NOT need to rebuild qgis at all. You can just start
hacking into one of the existing easier plugins (sources) into (on
windows where you apparently are developing in)
"C:\Documents and Settings\[YOURNAME]\.qgis\python\plugins"
So install qgis and python, and install for example the "Raster File
Info" plugin via the plugin-installer OR by just extracting the zip from
: http://spatialserver.net:3001/python_plugins/list?page=2
into your C:\Documents and Settings\[YOURNAME]\.qgis\python\plugins
directory.
As you can see, you can use existing plugins to peep into the source for
ideas etc. There are already some postgis-related plugins available
(from: http://spatialserver.net:3001/python_plugins/list):
- PostGPS: A set of dialogs for converting a point layer into a .gpx
file and to take a any point layer and insert it into a PostGIS table
- NewLayer  	Example of how to create a new minimal PostgreSQL layer
with predefined field types (not very useful but demonstrates the concept).
- pypostgis  	Plugin to run queries from inside qgis and load them into
the canvas. Uses OGR as connection library.
One remark: in this time (just before the 1.0 release of qgis) there are
some api-changes, so beware of that).
Another remark: there is also a difference in making a plugin with nice
dialogs, of plugins with only  msg-box-like alerts.
Developing plugins with dialogs you will need to set up qt and pyqt to
build those dialogs. But I would say: start with alerts first ...
(see my first steps in plugins: http://www.duif.net/qgis/ with some
links in it)
Regards and have fun,
Chang, Elizabeth wrote:
> Hi,
> I recently started looking into building a QGIS plugin in that would
> connect to PostGIS and be able to edit database entries.
> How do I go about starting this? I want to make an external plug-in. I
> started creating the development environment following
> http://www.webalice.it/marco.pasetti/qgis+grass/BuildFromSource.html and
> ran into problems. I’ll have to try it again and get the exact error
> message but in short, when I got to installing GRASS, it said that it
> couldn’t find Lex. I had installed Flex by downloading the prebuilt
> binary package and somehow GRASS installation couldn’t find it. When I
> went to reinstall Flex by building it myself, I think it said that it
> couldn’t find Bison which I had also installed using prebuilt binaries.
> How do I get it to find Flex and Bison? BTW, I’m building this on
> Windows using msys.
> In the meantime, I ran into
> http://wiki.qgis.org/qgiswiki/DevelopingPlugins?highlight=%28plug%29
> which is outdated but seems to say that I don’t need the entire
> development environment.
> Could someone give me any pointers on this endeavor? I’m a newbie. I
> know some programming in Java but not on C++ or Python and planning to
> learn what I have to learn to do this.
> Thanks,
> Elizabeth
> Qgis-developer mailing list
