[Qgis-developer] White space bug?
Stefan Muthers
stefan.muthers at zamg.ac.at
Fri Oct 17 02:33:47 EDT 2008
hello,
I use Qgis 0.11.0 under Windows 2000. The grass environment is installed
by osgeo2w[1]. Grass version is 6.3.0 (2008).
When I import shapefiles with whitespace in the pathname, I get an error
message.
for example:
$ v.in.ogr 'C:/Dokumente und
Einstellungen/user/Desktop/Daten/Bsp/Example.shp' output=line
$ v.db.addcol map=line columns='test double'
ERROR: value <und> out of range for parameter <driver>
Legal range: dbf,ogr,pg,sqlite
Description:
Executes any SQL statement.
Is this a bug? Maybe similar to Ticket #1005 [2].
regards
stefan
[1] http://trac.osgeo.org/osgeo4w/
[2] https://trac.osgeo.org/qgis/ticket/1005
