[Qgis-developer] PostGIS manager
Martin Dobias wonder.sk at gmail.com
Mon Oct 27 15:55:24 EDT 2008
On Mon, Oct 27, 2008 at 8:05 PM, John C. Tull <john.tull at wildnevada.org> wrote:
> Ok, after that install, the plugin loads.
> I get a nice list of all my tables and the meta data is listed, but nothing
> shows under the table or preview tabs. I am not running a debug build, but
> can make one and give error messages if you'd like.
The plugin should be able to show table and map for tables that are
accessible within QGIS. If you can open them within QGIS and not in
plugin, something's wrong with plugin and debugging output might be
useful to track down the reason.
> This did pop up in the Console when I opened the plugin:
> 10/27/08 12:04:06 PM [0x0-0x24d24d].org.qgis.qgis[80700] Warning:
> QgsCoordinateReferenceSystem::findMatchingProj will only work if prj acr
> ellipsoid acr and proj4string are set!...
This shouldn't have any impact on the problem.
Bye
Martin
