[Qgis-developer] MetaEdit Alpha Release
Alex Mandel tech_dev at wildintellect.com
Mon Apr 6 14:29:51 EDT 2009
Ah, yes some xml documents aren't loading. You are the second person to
report such an issue, and we now have a hint to look at handling the
character encoding more gracefully.
I encourage people to file bugs on our project trac
http://apps.sourceforge.net/trac/qgismetaedit/
I'm pretty sure all you need is a sourceforge account.
Thanks,
Alex
godofredo contreras wrote:
>  Hi Alex:
> I have downloaded your plugin and in my windows xp machine and have found the following:
> * Open template fails with the message "loadDoc:: Failed to load: C:/Documents and Settings/freddy/.qgis/python/plugins/metaedit/Templates/xml/ISO19139_elements_es.xml 'ascii' codec can't encode character u'\xf3' in position 7: ordinal not in range(128)"
> Regards
> Godofredo Contreras
>> Date: Sun, 5 Apr 2009 17:12:53 -0700
>> From: tech_dev at wildintellect.com
>> To: qgis-developer at lists.osgeo.org
>> CC: qgismetaedit-developers at lists.sourceforge.net
>> Subject: [Qgis-developer] MetaEdit Alpha Release
>> All,
>> Our class has ended and we have a very early stage plugin available for
>> tinkering. Currently it's more of a metadata reader but we hope to get
>> full read/write in the coming months. As such we would like to invite
>> any interested parties to help out on the plugin in any way that you
>> like, coding, gui design, research on xml standards, xml rendering in
>> web pages, documentation etc.
>> All you need is a sourceforge account, the project trac is
>> The initial release is in the User Contributed Repo, although I
>> recommend you svn checkout to stay up to date and to have access to more
>> testing files.
>> If you are interested in commit access just send me an email.
>> Thanks,
>> Alex
