[Qgis-developer] Mac users: comments wanted on Xcode project
Gary Sherman
sherman at mrcc.com
Fri Apr 10 22:13:10 EDT 2009
On Apr 10, 2009, at 1:53 PM, William Kyngesburye wrote:
> Well, for a while now, I've been keeping an eye on commits and
> updating the Xcode project (in trunk/v1.1) as needed. It's gone
> quite smoothly, except for large commits getting filtered out of the
> commit list so that I miss them for a while.
> But, except for one person that's had some trouble with it
> (resolved) and given me a few ideas that I've implemented, the Mac
> users and developers have been pretty quiet. Have the Mac folk
> tried using the Xcode project to build Qgis? I would like to hear
> some feedback. Some things in particular to think about:
Funny you should ask---I tried it today and had trouble that was
resolved by starting with a clean (checked out) source tree. I found
that editing a .ui file and doing a build didn't pick up the changes.
A clean was required first.
> - Does the configuration make sense? Is it simple enough to not
> scare people away? It's a manual configure by editing a text file,
> though out of the box it should work with my frameworks and a few
> standard extras without any config edits.
It would make sense if I had a clue :) I'm afraid I still don't know
my way around the source and target folders very well.
> The current configuration also does not verify dependencies. But
> for many cases, this is unnecessary, like system libraries, because
> it's not trying to understand many very different systems, only
> OSX. If something isn't found where expected or configured, you
> won't find out until the build fails.
> A configure script is on my list of things to look into. Maybe it's
> possible to hook into the cmake configuration, that would be nice...
> - Most optional features are requirements in the Xcode project due
> to the lack of conditional sources (for things where a complete
> source file is added to core or gui components). Plugins are
> optional in a manual fashion - select the target and build. Source
> fragments are conditional in the usual #ifdef manner. This could be
> used to wrap optional sources into an #ifdef + #include, if there is
> interest in having the same configurability as the cmake build, but
> I'm not sure it would work for moc sources.
> - Debugging - has anyone tried debugging Qgis from the Xcode GUI? I
> don't know much about it, though I did debug a program once in Xcode
> (or, I successfully started the debugging process, but didn't
> understand the output enough to track down the problem).
Yes I tried this today. The only problem was I don't seem to have the
debug libraries for Qt so it wasn't all that helpful for the task at
hand. Otherwise I think it will be quite useful.
> - Bundling - I've tested bundling of dependencies in the default
> framework-based configuration + a couple libraries where needed. I
> haven't tried an all-in-one bundling of only libraries, like Tom's
> build. It should work. It's even possible to bundle frameworks
> (other than the Qt frameworks, which are always bundled) for a
> framework-based all-in-one, but I haven't had a chance to test this.
> There is also an option to bundle extra non-Qgis files. This was
> necessary for a PyQt addon (Qwt5) needed for a plugin. I found that
> this PyQt addon (possibly others) must be in the PyQt namespace,
> thus must be bundled with PyQt in Qgis. This is unfortunate as it
> goes against OSX conventions that addons/plugins/... should not be
> added to an application package as a separate installation, but
> instead be installed in a known plugin location for the app (Qgis
> python plugins do this, of course). So, in this case, you couldn't
> add a plugin based on Qwt5 to a standard distributed Qgis app.
Overall I find the Xcode project useful and worth continuing. Thanks
for all the hard work.
-gary
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
> Qgis-developer mailing list
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Chair, QGIS Project Steering Committee
-Micro Resources: http://mrcc.com
*Geospatial Hosting
*Web Site Hosting
-Desktop GIS Book:
*http://desktopgisbook.com
"We work virtually everywhere"
