[Qgis-developer] osgeo server
Paolo Cavallini
cavallini at faunalia.it
Sun Apr 12 02:34:41 EDT 2009
Paolo Cavallini ha scritto:
> Since now and then I get errors from the server:
More errors (python 2.3, brrr!):
Oops…
Trac detected an internal error:
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 387, in
dispatch_request
dispatcher.dispatch(req)
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 191, in
dispatch
chosen_handler = self._pre_process_request(req, chosen_handler)
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 263, in
chosen_handler = f.pre_process_request(req, chosen_handler)
File "/usr/lib/python2.3/site-packages/trac/versioncontrol/api.py",
line 73, in pre_process_request
self.get_repository(req.authname) # triggers a sync if applicable
line 101, in get_repository
repos = self._connector.get_repository(rtype, rdir, authname)
File "/usr/lib/python2.3/site-packages/trac/versioncontrol/svn_fs.py",
line 260, in get_repository
crepos = CachedRepository(self.env.get_db_cnx(), repos, None, self.log)
File "/usr/lib/python2.3/site-packages/trac/versioncontrol/cache.py",
line 34, in __init__
self.sync()
line 56, in sync
cursor.execute("SELECT value FROM system WHERE name='repository_dir'")
File "/usr/lib/python2.3/site-packages/trac/db/util.py", line 51, in
execute
return self.cursor.execute(sql)
File "/usr/lib/python2.3/site-packages/sqlite/main.py", line 244, in
execute
self.rs = self.con.db.execute(SQL)
OperationalError: database is locked
Paolo Cavallini: http://www.faunalia.it/pc
