[Qgis-developer] osgeo server
Tim Sutton
lists at linfiniti.com
Sun Apr 12 03:27:03 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
Paolo Cavallini wrote:
> Paolo Cavallini ha scritto:
>> Since now and then I get errors from the server:
Trac seems to be working for me here. If its down the place to report it
is at http://trac.osgeo.org/osgeo/ filed under component SAC. Of course
if that is down too then we are toast :-)
Regards
Tim
> More errors (python 2.3, brrr!):
> Oops…
> Trac detected an internal error:
> Traceback (most recent call last):
> File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 387, in
> dispatch_request
> dispatcher.dispatch(req)
> File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 191, in
> dispatch
> chosen_handler = self._pre_process_request(req, chosen_handler)
> File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 263, in
> chosen_handler = f.pre_process_request(req, chosen_handler)
> File "/usr/lib/python2.3/site-packages/trac/versioncontrol/api.py",
> line 73, in pre_process_request
> self.get_repository(req.authname) # triggers a sync if applicable
> line 101, in get_repository
> repos = self._connector.get_repository(rtype, rdir, authname)
> File "/usr/lib/python2.3/site-packages/trac/versioncontrol/svn_fs.py",
> line 260, in get_repository
> crepos = CachedRepository(self.env.get_db_cnx(), repos, None, self.log)
> File "/usr/lib/python2.3/site-packages/trac/versioncontrol/cache.py",
> line 34, in __init__
> self.sync()
> line 56, in sync
> cursor.execute("SELECT value FROM system WHERE name='repository_dir'")
> File "/usr/lib/python2.3/site-packages/trac/db/util.py", line 51, in
> execute
> return self.cursor.execute(sql)
> File "/usr/lib/python2.3/site-packages/sqlite/main.py", line 244, in
> execute
> self.rs = self.con.db.execute(SQL)
> OperationalError: database is locked
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAknhl70ACgkQqk07qZdiYjfkoQCfSiUz1EJoOytKpoOfelTe+lSH
jmkAnRUKad0J41KjDvojxcjickFOKd7C
=YPKi
-----END PGP SIGNATURE-----
