[Qgis-developer] QtCreator and QGis
Abhay abhay.menon at gmail.com
Mon Apr 13 07:59:29 EDT 2009
Hi martin
As I know the new qtcreator 1.0.1 has the tool
Tool>options cmake and qt setup options.
My reason to ask for qtcreator is to know is the same app can create
in multiple platform
As I use windows most of the time switch between windows and Linux
with different IDE all the increase chance of choas all the time as
needing to remember all the time
Rdgs.
Abhay.
On Monday, April 13, 2009, Martin Dobias <wonder.sk at gmail.com> wrote:
> 2009/4/12 Lynx <lynx21.12.12 at gmail.com>:
>> On Sunday 12 April 2009 18:45:26 Abhay wrote:
>>> Hi All,
>>> Has anybody used qtCreator with qgis source code for development purpose.
>>> If so could you please post the step to how to implement the same.
>>> Thanks and Regds.
>>> Abhay.
>> Hi Abhay,
>> I am using QtCreator with QGIS source for development purpose. I have set of *.pro files that contain the necessary lines to build QGIS on my machine. So i attached theirs and the script that put theirs in properly directories. To use it put the archive in QGIS directory and unzip, then change dir to prodir and run script ./pro_file_struct. After that you should correct some .pro files to build QGIS (if you have some packages in no standard path). Well, i hope it will be useful :)
> Hi,
> I'm also interested in using QtCreator for qgis development, but I've
> been too lazy to download and install it :)
> Anyway from what I've heard, now Qt Creator should support also cmake
> so there is not need to use qmake... or am I wrong?
> Martin
> Qgis-developer mailing list
