[Qgis-developer] QtCreator and QGis
Martin Dobias wonder.sk at gmail.com
Mon Apr 13 07:22:15 EDT 2009
2009/4/12 Lynx <lynx21.12.12 at gmail.com>:
> On Sunday 12 April 2009 18:45:26 Abhay wrote:
>> Hi All,
>> Has anybody used qtCreator with qgis source code for development purpose.
>> If so could you please post the step to how to implement the same.
>> Thanks and Regds.
>> Abhay.
> Hi Abhay,
> I am using QtCreator with QGIS source for development purpose. I have set of *.pro files that contain the necessary lines to build QGIS on my machine. So i attached theirs and the script that put theirs in properly directories. To use it put the archive in QGIS directory and unzip, then change dir to prodir and run script ./pro_file_struct. After that you should correct some .pro files to build QGIS (if you have some packages in no standard path). Well, i hope it will be useful :)
I'm also interested in using QtCreator for qgis development, but I've
been too lazy to download and install it :)
Anyway from what I've heard, now Qt Creator should support also cmake
so there is not need to use qmake... or am I wrong?
Martin
